Lee Hrber
Posted on - 08/04/2019
I was browsing on the internet on my computer when I got the blue screen of death out of nowhere. The blue screen 0x0000001a code was displayed along with something is wrong with your computer. Can someone help?
Blue Screen 0x0000001a Death Screen Windows 7
Blue screens are really scary because they only occur when something is seriously wrong with your computer and can sometimes indicate a fatal error or problem with your computer. The error code 0x0000001a indicates that there is a memory mismatch problem due to which you got the blue screen.
The problem is that you either have a defective or mismatched RAM installed on your computer. If you have changed the RAM sticks on your computer recently, this error can take place. One thing you can do is to try different combinations of the RAM sticks to see which one works. Also, check if all or one of the sticks is defective. A defective RAM stick is harmful to your computer’s health.
