Sometimes a blue screen appears on my laptop screen, my laptop model is ‘Dell D630’, and two times I lost my important data. When blue screen appeared then I plug off the adapter and remove the battery to restart the laptop, because I tried a lot to restart the laptop with power button or press again and again ‘Ctrl + Alt + Delete’, but not working. I reinstalled windows 7 by a new CD but the problem is still here. I don’t know whether it is a hardware problem or software problem. Give me some suggestions.
Blue screen appear on laptop screen Dell D630
Blue screen on appear at. This is common error. Many people are facing this problem while they are new to laptop. to solve this problem what you have to. restart your laptop and go to your Rom setting by pressing F8 key.
look at the options appear there is will display the current ATI setting of your laptop. change these setting to the next one and select save. and then again restart your laptop.
It will load Operating system and you will never face this problem again. What you have to keep in your mind that when you laptop become moderately hot then shutdown your system to cool it or install an extra fan.
Thanks
Peter123
Hi!
BSD sometimes also called the blue screen of death not only appears in laptops but also appears in personal computers. It always appears due to insufficient memory available. Check your system settings for available memory or simply either uninstall some heavy softwares or reinstalling windows could also be an alternate remedy for this issue.
Hope it helps.
