Blue Screen of Death (BSOD) Problem
What is the cause of Blue Screen of Death (BSOD) when it shows up in a computer? How can I fix my computer if I encountered a Blue Screen of Death problem?
Dear Burton Tag. These are some causes as well as fixes for this error.
I hope this will help.
The blue screen error happens when a system failure is encountered. This error is similar to fatal error which you usually encounter in common programs. The blue screen error appears usually when you install a program that causes the system to fail or a hardware you added on your motherboard.
When the cause of the problem is the hardware you installed, it is not usually the hardware that directly causes the error. It is the program or software associated with the hardware that causes the error because it is the main component that has direct contact and communicates with the system.
When you encounter the blue screen error, the first thing you should do is to remember if you had a recent installation. If you have no previous or recent installation on the computer, just turn off the CPU and then turn it back on. It is probably just a normal glitch in the system. I usually encounter this.
But if you are installing something and the blue screen appeared, you should uninstall the program. You can uninstall the program in Safe Mode if the computer keeps on showing the blue screen. Once the computer is running normally again, install a different version of the program. If it is a driver for your hardware, look for another version compatible with your machine.
Notifications
