Blue Screen of Death error
Here’s what I experience.
“System Rebooting. Can't Read Error Message” error. I get the blue screen of death but it flashes by too quickly and I can't read it. What should I do?
There are so many reasons why blue screen appears. The common problem of this error is that your memory has a problem. Your memory might be total damage or it was just having a little loose connection.
To solve the memory problem that causes blue screen, try to remove your memory and erase the pins to make it look like golden metal. Put back the memory after cleaning then test the computer if it works now.
Some other reasons are corrupted windows libraries and components, CHKDSK scheduling during boot up helps in this kind of problem. Boot in safe mode then runs the command line interface or the CMD.EXE then type CHKDSF /F at the command prompt.
Try these steps:
Right click on My Computer then selects Properties got to the advanced tab. Now Click Settings under 'Startup and Recovery' and uncheck 'Automatically restart'.
Hope this helps!
Notifications
