Blue Screen of Death on Windows XP installation process
Whenever i try to install windows xp it shows blue screen middle of the copying file,what should i do?
If you are installing Windows XP on the laptop, make sure you put the hard disk in 'Compatibility mode' in the BIOS, which was by default 'AHCI'. Do go to settings as soon as you turn on your PC and follow the steps below:
If the installation fails again, there are many issues that perhaps the blue screen. You can be a faulty RAM that can be found in any of several areas, including the RAM cache secondary, the video RAM or the computer's main memory. To determine where the faulty RAM, use the following steps:
Lucky!
You will need to follow the steps below to try and overcome the blue screen error when you are installing the windows XP operating system.
-Clair Charles
