Blue screen with an error message
While working in my computer I experienced a blue screen and I couldn’t do any work with that.
Then it gets an error message "Windows XP Stop 0x0000001E Error".
Why does this happen?
Please explain me.
Please explain me.
Windows XP kernel has detected an illegal or unknown processor instruction in your system.
You can find the problem and its reason.
The driver or faulty hardware that caused the issue usually indicated by the exception addresses.
When you experience a blue screen while you are working with your computer, it is a critical error should be fixed immediately to prevent further damage of your hardware and software in your computer. So therefore you will have to check all the registry entries manually, these procedure is long and exhausting.
It will take a few days to handle this error, so therefore I recommend you to back-up all your files and format your computer, maybe its because the registry of your computer might be corrupted by the Virus found in your computer that you will not know.Â
So I hope this will help you for this solution.
This event can happen if you restart your computer during or after the Windows Setup process.
Some causes of such problem are the following:
1. There is lack of disk space on the drive where your Windows is installed.
2. There is an outdated or incompatible third-party driver or sometimes drivers installed on your computer. Example of which is an outdated video card.
Resolution Methods:
Such type of problem usually can occur when someone restarts the computer during or after the Windows Setup process. If any of the following conditions are true then there are following possible reasons:
There are three following possible solutions to resolve this issue, use any one of the following methods as appropriate to your situation.
Method 1: Free Up Disk Space:
Make sure that the disk on which you installed Windows has sufficient free disk space. If it doesn’t have enough space then reinstalls Windows to another disk, which has sufficient free space.
Method 2: Disable or Remove the Third-Party Driver:
If the STOP 0x1E error message shows a driver by name, then disable or remove that driver. Then reinstall the windows. If this solution resolves the problem then it is ok. If you want to install that third-party hardware then contact the manufacturer to obtain more information about how to get the latest version of the driver.
Method 3: BIOS up gradation:
To upgrade your system BIOS, you must contact the motherboard manufacturer of your computer. Microsoft Debugging Tools is also very helpful to obtain more information about this error message. Go to the following Microsoft Debugging Tools Web link to download, install, and use the Debugging Tools:
Hi good day,
You can fix this kind of error you can visit this link.
The explanation of this error was in here. Please read carefully while you proceeding your task.
I don’t want to talk more just go and visit the link that I mention above.
Thank you, hope its help.
Regards;
logictor
