Blue screen irql not less or equal windows 7
60 points
Posted on - 02/12/2015
I am using Window 7 and is there any way to solve the problem. While using my system normally and doing the routine work suddenly an error comes in Blue Color to the whole screen “IRQL_NOT_LESS_OR_EQUAL” and the system stopped working and then nothing happen until I force turn off the system and turn it on again. This error comes in suddenly some time it comes after 2 hours and some time it comes after 5 to 6 hours. I do not what is causing that problem to occur.
