Blue Stacks V 0.9 installation problem
Why am I having problem while installing the latest version of blue stacks 0.9? It says something like low graphics when I have an NVIDIA 9800 GT. Why is the problem occurring? Have I downloaded some corrupt file? Is my graphics card really bad? What is the cause of the problem? Should I download a new version of blue stacks or should I consider upgrading my 2 Giga Bytes of Random Access Memory? Please mention the source of such problems.
Answered By 5 points N/A #194131
Bluestacks is the best Android emulator for both general usage and for developers. Though it’s an awesome software, installing it is a great trouble sometimes.
Bluestacks require minimum free RAM space 2GB, OpenGL support 2.0 or later and 9GB free disk space. If you have anything less, you can’t install Bluestacks.
It’s strongly recommended to have 4GB RAM on any PC or computer for better performance. Also, graphics driver is a great cause that you can’t install Bluestacks on your PC. You should get the latest display driver from the manufacturer of your graphics card.
So, update your graphics driver and upgrade your RAM to at least 4GB for having Bluestacks.
Answered By 5 points N/A #194132
