Hello There! I have a Dell Alienware 14 inches Laptop, this is a brand new unit and my problem is that I am seeing a blue vertical line across the screen. Is this normal? Please advise what to do, restarting the machine did not help. Hope you can help. Thank you.
Blue vertical line on the screen of my laptop
Hi Moses,
It is not normal that you have a blue vertical line across your brand new laptop screen. It is not a software issue either as restart didn't help your cause.Â
Most probably it is a hardware issue, your display might have been damaged. Contact your service center with appropriate papers, they will handle it.Â
Affirm this motherboard or perhaps movie chipset as being the cause of the challenge simply by hooking up this notebook to an outer check or perhaps TELEVISION. When the outer present is standard, simply no directory outlines, this motherboard along with movie chipset are operating commonly. When the outer present contains the similar trouble, you could have to switch this movie minute card or perhaps motherboard.
Look at this laptop's movie cable, admittance this movie cable of which connects this TV screen for the motherboard. Check it really is pushed firmly into the fittings, lightly fold this cable, or perhaps swap this cable along with check this present.
In the event that not one on the previously mentioned work, you could have to switch this TV screen per sec.
In most cases, directory outlines on a laptop's TV screen are brought on by this TV screen destruction. When the outlines adjust colour or perhaps get broader or perhaps narrower once you apply bit of a force in the returning on the cell, the thing is likely brought on by this laptop's LCD TV screen along with must be replaced."
