noah powell
Posted on - 11/14/2013
Hi All,
I have a laptop with which the audio quality is bad so i wanted some info on Blue Yeti is this a good Microphone
Can i have few competitors for this device so i can select from the best
Detailed info on technology/price/quality would be great
Blue Yeti Audio Microphones quality
    The blue yeti is a good brand when it comes to microphones perhaps the best, still please check all the competitors before buying. At this point the Blue Yeti is indeed the top of the list.
The competitors are
1. Blue snowball
2. Audio Technica AT-2020
3. Apogee One
Please check these links for prices and quality comparison.
Hope you had your answer! 🙂
The Yeti is one of the most advanced and powerful USB microphones available anywhere. It combines with 3 capsules and 4 different pattern settings. Now if you choose amazon, you can get it at 110$ with free shipping.
Features –
4 settings; Omnidirectional, bidirectional, cardioid, stereo.
Master Volume.
Mute button.
Proprietary tri-capsule array.
Mic gain control.
Zero latency headphone output.
USB mini jack.
Possible competitors –
Hope it helps!
