I have a lot of free space on my SD card and still this error appears when I connect my phone to my PC. I don’t know why it keeps saying that I have to uninstall some apps to free-up some space. Does anyone experienced this kind of error ? How can I solve this error ?
Thanks !
The internal SD Card in the free version of the BlueStacks App Player you are using is full. You are welcome to uninstall one or more apps to free-up space, or upgrade to the BlueStack App Player Pro version to be able to install additional apps without.
BlueStack Apk Handler
Apk Installation fehlgeschlagen: INSTALL_FAILED_INSUFFICIENT_STORAGE
OK
points
BlueStacks Apk Handler internal error if SD Card
Bluestacks is one of the best Android emulator software all over the market. It allows fast, efficient access to Android apps. APK files can be installed and played very easily. But the main problem is, it has got several limitations. It mounts a single SD card that gets a little amount of disk space. You can either increase the size of the SD card or remove some apps that are taking large disk space.
In order to identify the apps that are taking large disk space,
1. Launch “Settings” from “All Apps”.
2. From the left panel, tap into “Apps”.
3. Select “ON SD CARD” section.
4. Identify those apps that are taking a large portion of disk space and uninstall them.
If you don’t wish to do so, you can see this tutorial to increase SD card size according to your wish.
