BlueStacks graphic card and drivers error
Hello experts,
A friend of mine recommended to install BlueStacks App because I can have access to many apps for my devices. While installing the software I have this error. I don’t know what this error means and why I have it since most of my friends are using it ? Does anyone can help me to fix it ?
Thanks !
BlueStacks Install Wizard
This installer has an invalid digital signature. It was probably damaged while being transferred over the network or loaded from damaged storage media. Please download a fresh copy of this installer from www.blustacks.com and try again.
Answered By points N/A #179959
This error message indicates that the installer of BlueStacks is corrupted while downloading or in other way that is making it unable to complete the installation because of corrupted data. In order to successfully install the software, you have to get a completely fresh installer.
Download latest BlueStacks Offline Installer. After downloading, run the installer. It should work fine without having any corrupted installation data.
Also, you’re suggested to use any good download manager to download the file as it is a large one. Use Internet Download Manager (IDM).
Hope no more issue.
