BlueStacks installation failed due to some compatibility issue
Hi Professionals,
When I am in the process of installing the BlueStacks in my computer, I stuck up with an error message. And installation failed leaving the below error message. But I already uninstalled the RocketDock from my computer; no longer using it. But still I am getting this error message. I did the un-installation long back, why I am getting this now? Please help. Your help is great. Thanks in advance.
RocketDock is installed on your machine. BlueStacks is not compatible with RocketDock. Please uninstall it and try again.
Answered By points N/A #191972
BlueStacks is the best Android emulator to run Android apps on Windows PC. I also use BlueStacks but it never gave such error. Sad to hear in your case.
BlueStacks is incompatible with any sort of Dock programs including RocketDock. So you can’t install BlueStacks perfectly.
Start Notepad, copy and paste the following text (without quotes) and then save anywhere with the file extension .reg
“Windows Registry Editor Version 5.00
[-HKEY_CURRENT_USERSoftwareRocketDock]
[-HKEY_CURRENT_USERSoftwareStackDocklet]”
Double-click the registry file and if prompted, press “Yes”. It will give a warning message. Just ignore it and press “Yes” again.
This time, BlueStacks will definitely install without any error.
