Bluetooth and phone remote control key maps , any help?
Hi everybody, Is there a link between bluetooth and phone remote control key maps please help, Thank you
Yes, there are links between Bluetooth and phones. The links allow mobile phones to be used as remote controls for variety of uses through Bluetooth device. Mobile with remote control is an example; this software allows your mobile phone to act as a remote control for your desktop while utilizing Bluetooth technology. Another example is Vectir 2.7 which provides almost the same functionality as mobile with remote control but what sets it apart is that it also utilizes WiFi.
With the help of Bluetooth technology or connectivity, any Smartphone, iPod, and other Bluetooth-enabled devices can be used as remote controls. An example of using these devices as remote controls would be the Logitech Mini Boombox. It is a Bluetooth speaker which can be paired easily with Smartphone, iPod touch, iPad, and other devices that works on Bluetooth wireless audio profile [A2DP].
Using your Smartphone handset or iPad as a remote control, while playing music on your device you can easily stream it to the wireless boombox. But streaming music from your Smartphone to the wireless boombox has a limitation. Your Smartphone or iPad must be within 10 meters or 33 feet away from the wireless Bluetooth boombox. The Logitech Mini Boombox is a compact, rechargeable, and delivers great sound. It is priced at £69.99.
First guys, take my compliment and thanks for your crucial advice. I think that Techyv.com is the highest seat of learning about the newest technology as well as problem solution provider too. All viewers could find their solutions about their problems by visiting this site. Both of your solutions were credible and approachable but Sharath your comment was head and shoulder’s much superior to me. You are a good solution provider and I am so very proud of you. I believe, a good solution is like a having the salt of life which I have found from your solution. Really The Logitech Mini Boombox idea is a great one which is new to me as well its awesome visages touched my mind. Thanks Sharath for providing me such nice information.
