Bluetooth case and keyboard for i-pad
I am planning to buy a bluetooth keyboard for my i-pad.I would also like to buy a casing for the pad.Can you please recommend which one to buy.The keyboard must be a bluetooth device and have long battery life.
For the casing, I would recommend iPad smart cover. It comes with great features.
Old is gold; after using iPad and falling in love with it, the one thing you feel missing is a keyboard. Apple feels the same that is why there are various accessories, a Bluetooth keyboard casing is one of them.
For iPad and iPad 2, I recommend "Kensington keyfolio pro keyboard case for iPad and iPad". it cost from $80 to $100. And has the following features…
Hope this works; if you need further work, then please do contact us.
According to my research I recommend the Kensington KeyFolio, This is a Bluetooth keyboard case for Ipad and Ipad 2 it is made of synthetic leather. You can also use the case as a stand; it has also access to your charging port along with the volume and your power button at the top. It also has a built-in keyboard and it's connected by Bluetooth. The keyboard is rubberized and it comes in 400 MHz it has a lithium ion battery that last for 90 hours if full charge and it can be lost for 45 days in standby mode. The case is studded it covers up the entire device the KeyFolio will be a great accessory for your iPad device. Hope this will help with your shopping.
Notifications
