I am using Nokia3110 classic in my PC, and I use Ubuntu 11.04. I connected a blue tooth device in a USB port. When a turn on my PC there comes a dialog box there is no blue tooth device or Bluetooth device is disabled. Some time Bluetooth works. Why do these problems occur?
Bluetooth device not found or disabled
First to all did you installed its driver software? A Bluetooth device needs its own driver software. Windows cannot detect Bluetooth device that means there is a driver problem in your windows system. Every Bluetooth needs its own driver software so that windows can drive this device perfectly. So install that particular driver software.
You must have to use its dedicated driver software. If you don’t have just downloaded it form https://filehippo.com/.
If you have a plug and play Bluetooth device then do not need to install driver software. In this case driver software will install automatically. If it is not working then connect it with different USB port and wait for a while to detect Bluetooth device.
