Bluetooth headseat links to severe headaches
I am an avid user of Bluetooth headsets. Recently I purchased a headset, am no longer sure of the make. The issue that I have been having with this device is that it is giving me severe headaches. I am not sure if it is the headset that is causing this. Has any studies proved that Bluetooth is connected with headaches?
Answered By 0 points N/A #189305
I wanted to let you know that the problems with the Bluetooth headsets are common now among many peoples. It seems that Bluetooth headsets are using a similar wavelength as that of microwaves, but most of the people who have got the Bluetooth headsets are not affected by it. Only 10% of people can be affected by the waves coming from the Bluetooth headsets.
I suggest you that do not use the Bluetooth headsets anymore; you can use normal headsets rather than Bluetooth headsets.
Hope this answer will help you a lot.
