Bluetooth Headset for iPod Touch 4th Gen
Which Bluetooth headsets work with iPod Touch (4th generation)? I want to use it for U streaming and I would like to use the mic from the headset. The forums I have read are about older generations.
Hello Thaddeus,
I am giving you the best choice for choosing the Bluetooth headsets for your 4G Ipod Touch. Find the following mentioned headsets that best works with the 4G Ipod Touch.
* Â JayBird Bluetooth Headphones
These are perfect Bluetooth headphones for iPod Touch 4G. With this OS running, you can make use of the JayBird headphones, and also enjoy remote track controls from the headphones. You can get these sporty looking headphones in a wide range of colors, and they will cost you anything up to $100 depending on which model you pick up.Â
* Â Motorola Motorokr s305
These headphones are also good for 4G ipod Touch. This is not a bad option for you.  If you are looking for something affordable, this is a fairly good buy, coming in at around $35.Â
Best Wishes
