Frank Trask
10 points
Posted on - 12/22/2013
Hi there,
I have been looking for Bluetooth keyboards for my Samsung Galaxy Note 10.1 2014 with no success, I have tried all compatible one but they keep on disconnecting now and then which makes it difficulty to work with this device, What could be the problem? How do I get the keyboards working okay?
Bluetooth keyboard problem with Galaxy Note 10.1
Well it seems that this is an internal error, what you do is try to disable your Bluetooth radar and then again reconnect this and if it doesn't work then reboot this. Another thing you can do is go to your Bluetooth settings screen and try to hold down the Bluetooth button on the back side of your keyboard for about five to ten minutes.
If none of these works then go for a Samsung update to solve the problem.
