Bluetooth skip Toshiba for Windows
Hello all,
I am using Toshiba Satellite C660 with Windows XP, Please send me the Bluetooth driver for that as currently Bluetooth skip Toshiba for Windows.
Thanks & Regards
Marie
Hello all,
Thanks & Regards
Marie
Hello Marie,
 If I got you correctly, you need a Bluetooth drivers for Windows XP, laptop model Toshiba Satellite C660.
To download them, Click this link.
Install it normally and restart your laptop.
Bluetooth should be working for you now.
Now your Bluetooth will be definitely working.
I hope this solution will work for you.
Hi Marie,
You can download the latest drivers for your Toshiba Satellite C660 Bluetooth Drivers for Windows XP and Toshiba Bluetooth Drivers for Windows by following the link below. It also includes drivers for AHCI Driver, BIOS Update, Card Reader Controller, Chipset Utility, Sound Drver, Touch Pad Driver, etc. Â
To download, click the link: Toshiba Bluetooth Drivers for Windows
To download, click the link: Toshiba Satellite C660 Bluetooth Drivers for Windows XP
Ware
