Blurriness engaging the monitor of a LCD
How will I fix my 14 inches Asus LCD monitor from displaying a shadow images. It becomes blurred already; I just bought it a year ago. I can't use this thing. I get teary eyes every time I was using my computer. It irritated me already. I check and tried the system restored but problem is still going on. I also check the button on the monitor at the screen display location; It's not the problem then. Do you guys have any idea how to fix this?
Best Answer by Marl Roger
Answered By 0 points N/A #81705
You can locate the cause of error of blurriness of your monitor; try to follow this steps. By simply hitting the reset key to reset your computer and select settings as required.. From the desktop, right click it and select properties from the menu. Choose appearance then click the effects button. Check the settings for effectiveness, while hitting the View menu. Now, go to Control Panel and click Gamma to reset your color scheme as you desired and wanted to. If using VGA card, check its own properties and check the gamma there. And restart your computer after all the methods above been tried. I hope it aid the error.
Answered By 0 points N/A #81707
Try to restore all display settings of windows to default. Right click on desktop and select properties then go to appearance and restore defaults. Also go to advance settings of properties and on your video card settings click restore defaults. Now on your monitor press the button for auto adjust which is just right beside the power button. If you still encounter blurriness then your LCD LED has a problem, better to which with new one or have it fix with the computer shop.
Answered By 590495 points N/A #325825
If you have a problem with your ASUS monitor like the image becomes blurry, try to uninstall and reinstall the video card driver. Download the free version of Revo Uninstaller and install it. Once installed, start Revo then select your video card software among the applications and click “Uninstall”. Follow the normal uninstall process.
When uninstall is complete, click “Scan” to scan your computer for any leftover files and delete everything it finds. This removes everything the program created on your computer. When it is finished, close Revo then restart the computer. After booting, install the video card driver back. If this doesn’t work, try updating the driver. Try downloading from the following manufacturers if you have one of these:
If this doesn’t work, try connecting the monitor to another computer and see if the problem follows. If the monitor has the same problem on the other computer, either bring the monitor to an electronics service center to get it serviced or buy a new monitor to replace it.
