BMC Remedy Pre-Configured Stack 7.6.04 SP2 Installation Failed
Hello
I found a problem in BMC Remedy software. While i was trying to set up, I got the error.
I am not finding any option for SQL authentication and also for username with password.
But previously I was login on it with my user ID and also I have admin rights.
What is the problem?
Please help.
Thanks in advance.
Installation Summary
The installation of BMC Remedy Action Request System 7.6.04 5P2 was completed successfully
See /tmp/arsystem_install_loq.txt.
ViewLog
Database client version is 11.2.0.1.0 and is compatible as per the compatibility matrix.
AR Server post installation check passed
Approval Server post installation check passed
