Boogie Board Jot capabilities and battery life
I saw this Boogie Board Jot which is a reflex LCD display where you can do your scribbles. Can you record and import your notes with this device?  Will it last the whole day of continuous note taking? What else can you do with it besides jotting down notes?
Best Answer by Loida Arcel
Answered By 0 points N/A #137197
The Device is powered by a replaceable coin battery that can enable 50000 erases.  This device can also saved a vector format of PDF that can be transferred from one device by means of micro USB port. The device is equipped with an internal memory capable of saving 200 PDF images. I can last a whole day of nonstop activity too.
Loida Arcel
Answered By 0 points N/A #137198
Hi Donna,
The Boogie Board Jot is an e-writer with reflex LCD. This means it uses power only to erase what you have written, so the battery can last for as long as a week.
  • The stylus has been designed to act as a stand as shown on the picture below.
  • The Boogie Board Jot has an erase lock to prevent you from mistakenly erasing your data.
  • You can import and export files to the Boogie Board jot from a PC using a mini USB cable. The import files will be in PDF format.
