Boot camp partition cannot open the disc
Hi guys
I have recently reinstalled windows xp pro on my system.
After its successful installation, I uninstalled and reinstalled fusion (version 1.1, build 62573) as it was giving me the following error before.
The screenshot is attached below:
Cannot open the disk ‘/users/beige/library/application support/VMware Fusion/Virtual Machines/boot camp/%2Fdev%2Fdisk0/boot camp partition.vmwarevm/boot camp partition.vmdk’ or one of the snapshot disks it depends on
Boot camp partition
I thought after a fresh reinstall it would work fine but still the same error persisted. I tried again by removing the boot camp partition file but still my problem was not solved.
Any help in this regard will be highly appreciated.
Kindest regards.
Answered By 0 points N/A #148971
Hi Jhonny,
There is a way to resolve this error connected with the issue of the boot camp partition.
Here are the steps to follow:
The file virtual disk which the virtual machine is pertaining must be identified:
First, back up the (VMX file) for future editing. Then follow these steps in the link:
Locate a line which starts with: scsi0:0.fileName = (or this) ide0:0.fileName =
In the line, after the equal sign, A file name is quoted. The file name which is quoted must not be a slice but either virtual disk or a snapshot disk.(For more information, these are the list of the file extensions and their descriptions: https://kb.vmware.com/s/
If the slice is pointed, make these necessary changes. For example,
Windows 2000 Home -000001-s007.vmdk" to "Windows 2000 Home -000001.vmdk
Or
"Windows Vista-s021.vmdk" to "Windows Vista.vmdk"
  • Then, before exiting, save the file in the setting file and exit.
  • After that, restart fusion.
  • Then run your virtual machine.
If the Problem is not resolved, follow the instructions.
Hope it’ll help.
