Boot camp Windows 8 Trackpad
I installed Windows 8 over Windows 7 in bootcamp. But mine Logitech Trackpad is not working in Windows 8, anybody has a solution on how boot camp Windows 8 trackpad works.
Hello dear,
You can fix this issue by following some steps which are given below.
1. First of all go to “device manager” and it will show in “settings” option.
2. After opening the device manager you will see two touchpad options under the “human interface drivers” option. Click on “ touchpad” option and then go to “general” tab then click on reinstall.
3. After second step this is the last step in this step you have to follow some smaller steps like search for the software automatically if it fails then choose the option “manually searching for the folder” then you should select “USB Input Device” and that will fix this issue.
There is also another way to get rid of this problem, Check this website.
Hope this will help you.
Notifications
