I'd like to boot an ISO image to read the VFAT file system without reformatting the drive. Is it possible to put an image in bootable dvd with ISO loader? I'm hoping that when I boot up the computer, I'd have the option on which image to boot. Thanks.
Is bootable dvd with iso loader possible?
Hello, Wilton Lanford!
You want to make a bootable DVD with ISO Loader. It is not possible with DVD disk. You can do it using a USB drive. You can do it very comfortably with a reputation you drive. You need to follow some steps to do this. Just plug the USB drive and then find the mount point. Install the GRUB2 file in the USB key. If you get an error message that embedding is not possible and failing back to UNRELIABLE black list setup, run. It will say put the ISO file into a USB media disk. It is not necessary to run the grub file again to add or remove ISO file.
Hope this helps solve your problem.
