Booting into a Graphical Environment
I have installed the X Window System recently. However, I cannot see any sign of a graphical desktop environment even after logging into the system. Can someone please help me in resolving this issue? Thanks.
Well, in such a case, you can always try to start the X Window System graphical interface by typing the command startx on the terminal. This, however, is just a temporary solution. It will not change the log in process for any future log in.
For a permanent set up, such that a graphical login screen is permanently available, you must do the following:
described target, that appears as a symlink to the specific target file.
root/admin account using the command “su”.
ln -s /lib/systemd/system/graphical.target/etc/systemd/system/default2.target
mv /etc/systemd/system/default2.target /etc/systemd/system/default.target
Log in afresh and you will be greeted with your graphical login prompt.
