Boundary Testing and Wrapping error
If increase the indent using the numeric, above and below the control buttons for 6.1 'or large we have an error message that indicates the size of the indent was too large, although the illustration of the preview window's character by wrapping to the next line!
The indent size is too large
Microsoft Office Word
The indent size is too large.
Why was it happening this way? What is the reason of this? Please explain with key words.
Answered By 10 points N/A #152974
Hello Ryan Abate
Hope you are fine.At first Check the enu Format & and search paragraph click to check the paragraph indent option.Secondly from Format menu select and click Tabs. At Tab box try to chnage the width and than select ok. At upper version sof Microsoft Office  check out this rules-hope this will help you.Opne Microsoft Office document word file first, select paragraph and chnage the indentation.Left-0.2".After that save the document as a word template.Now search: C:UsersanswertipsRoamingMicrosoftTemplates.Now name the doc Normal.New dotm and close Ms-Word.Again go to run: C:UsersAnswertipsRoamingMicrosoftTeplates and rename the normal.dotm file to normal_old.dotm .Now find Normal_new.dotmfine and rename that Noral.dotm. Now for the future time The Default indent is 2 for all time.Hope this will help you.
With Thanks
Greaney Mary
