IS Boxe system in XML document error
Hi there,
I have this XML error on ISBoxe Suite Startup and I am a bit amazed about this long error. No idea what it means or how it can be solved. Can anyone help me please to fix this ? What is causing this and should I be worried ?
Thanks !
System.InvalidOperationException: There is an error in XML document (1895,27).
–> System.Xml.XmlException: hexadecimal value 0x18, is an invalid
character.Line1895,position 27.
at System.Xml.XmlTextReadeImpl.Throw(Exception e)
at Sytem.Xml.XmlTexrReaderImpl.Throw(String res,String[] args)
at Sytem.Xml.XmlTexrReaderImpl.Throw(Int32 pos, String res, String []Args)
at Sytem.Xml.XmlTexrReaderImpl.ThrowInvalidChar(Int32 ois, Char invChar)
at Sytem.Xml.XmlTexrReaderImpl.ParseAttributeValueSlow(Int32 curPos,Char
quoteChar,NodeData attr)
at Sytem.Xml.XmlTexrReaderImpl.ParseAttirbutes()
at Sytem.Xml.XmlTexrReaderImpl.ParseElemen()
at Sytem.Xml.XmlTexrReaderImpl.ParseElementContent()
at Sytem.Xml.XmlTexrReaderImpl.Read()
at Sytem.Xml.XmlTexrReader.ReadEndElement()
at System.Xml.Serialization.XmlSerializationReader.ReadEndElemen()
at
Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationReadeInnerSpace
Settings.Read35_Set(Boolean is Nullable, Boolean checkType_
at
Settings.Read36_InnerSpaceSettings(Boolean isNullable, Boolean checkType)
Settings.Read37_InnerSpaceSettings()
—End of inner exception stack trace—
at System.Xml.Serialization.XmlSerializer.Deserialize(XmlReader xmlReader,
String encodingStyle, XMlDeserializationEvents events)
at System.Xml.Serialization.XmlSerializer.Deserialize(TextReader textReader)
at ISBoxer_Toolkit.InnerSpaceSettings.Load(String filename)
OK
