Keny bell
Posted on - 11/19/2012
Hi
I recently started to conduct IT classes for college students. I need to build a small computer lab to improve my classes. This is the first stage of my business and I cannot effort lot of money for this. So I need to know how to create custom built budget value PCs for my lab. I need to know the best brands and the performances.
Thanks
Brands and Performances of Custom Built Budget Value PCs
Hello Keny,
Congratulations to your new endeavor!
Selecting the best value computer for your lab is really crucial. It really depends on how exactly these computers will be used, meaning for what specific purposes. This should be taken to consideration to make sure that the PC you will buy is tailored to your needs. This is also crucial since the amount of money you will be spending has something to do with the computer specifications that you are looking for. Will you be buying it in store or online? Sometimes product offerings online differ from what they have in stores. It is only you who can decide which deals will be best for you.
You can checking with the following resellers:
Mwave.com
nwegg.com
Directron.com
Allstarshop.com
compgeeks.com
Some would prefer going to Best Buy or Circuit City.
Like I said, specific needs vary among users. So it would really help if you could at least note down your specifications. From there you could check which vendors have the best offers. If you are concerned about the brands, these are just some of the brands you may want to consider: Dell, Gateway, HP, Acer
I personally like to investigate online and check the best deals from online shopping. You may want to try that too!
