Brief For Onedrive App For Windows 7 And List Its Advantages
Hello, brief for onedrive app for windows 7 and notify some advantages for the easy reference as well. Thanks for solving.
Hello, the onedrive app for windows 7 is supported in all the OS for windows and its file size will not be more than 20 Mb. Also the same service is used on the desktop as well. It mainly integrates the desktop functions or other folder to the Pc as well as Mac. The files can be easily moved from one placed to other drives as well. Below shows its advantages:
• It gives the storage space for 25GB as the storage
• It has simple GUI for the users
• Has clean and light interface as well
• Also has the selective sync.
