Brief For Panasonic Dot Matrix Printer Kx-P1121e And Its Specifications
Hello. Notify the Panasonic dot matrix printer kx-p1121e specification for the same as well and brief for it as well. Reply ASAP and thanks.
Hello, the Panasonic dot matrix printer kx-p1121e is used in almost most of the windows OS such as in windows 2000/2003 and many others as well. If you want to download the software for the same then its file is not more than 4 Mb and can be downloaded over net easily. Below shows it specifications:
• It has a 24 pin impact of the dot matrix.
• Also has 360 x 360 draft speed for the printing.
• Can also support the A4 size as well.
• Its interface is parallel port.
• Can support in windows XP and N respectively.
