Brief For Pc Stress Test Software Free And Its Functions
Hello, brief about the pc stress test software free and also notify the functions for the same as well. Reply asap and thanks for solving.
Hey, the pc stress test software free is to limit the freeware with the stress test for the heavy loads. Also the same can be performed on the multiple processor cores as well. it can lost set the speed for the test files on the HDD. Below shows the functions for the same as well:
• It test how long will the PC battery goes off
• Also has the paint stress for the GPU
• The cpu stress on the CPU as well
• The HD-stress test will also test the HDD.
If you want to perform a stress test on your computer, you can try PassMark PerformanceTest. I have this one as an add-on on my Norton SystemWorks application and is really helpful if you want to know how fast your computer is. It also allows you to compare the stress results of your computer with other similar computers that have been tested.
The application is actually not free and costs around $27 to purchase but you can download it as a trial version and offers free 30-day trial period. It supports Windows XP Service Pack 3, Windows Vista, Windows 7, Windows 8.x, and Windows 10 including Windows Server 2003, Windows Server 2008, and Windows Server 2012.
It requires at least Intel Pentium IV or faster processor, 2 GB RAM, 300 MB hard drive space, and Microsoft DirectX 9-compatible video card. The following are the available standard tests:
