Brief For Ram For Dell Inspiron 1525 And Its Value Too
Hello, brief about the ram for dell inspiron 1525 and also notify the value for the same as well as a reference only. Thanks and reply ASAP.
Hello, the ram for dell inspiron 1525 will cost you approx. Rs 2,220 or more as per the product you go with. The same can be purchased from the online portals such as Amazon and also has some product warranty as well. The Ram has specifications such as the memory space for it is 4 GB, and also it has 2 slots of the same as well. The storage space will be in form of SATA 2 only. The chipset comes with the Intel GM965 respectively.
The Dell Inspiron 1525 laptop is among the priciest budget notebooks ever launched with a price tag of about $999. It ships with Microsoft Windows Vista Home Premium and runs on 2 GHz Intel Core 2 Duo T7250 processor, 2 GB RAM, 120 GB hard drive, and Intel GMA X3100 video card.
It has 8-speed DVD+R DL optical drive, Wi-Fi 802.11a/g/n, S/PDIF, dual headphone, S-Video port, HDMI, FireWire, VGA, 8-in-1 card reader, ExpressCard slot, 2-megapixel webcam, and four USB ports. It measures 14.5 x 10.8 x 1.4 inches and weighs 6 pounds with 1440 x 900 pixels widescreen native screen resolution. Standard battery rundown time is around 3 hours 45 minutes. It comes with 1 year warranty on parts and labor.
The laptop supports upgrading the memory up to 4 GB max. Among its cons is the Wi-Fi adapter that gives you an inconsistent connectivity. Its wireless performance was tested at a 50-foot range which gave an inconsistent connection but provided a respectable 19.9 Mbps throughput when it was placed 15 feet away from an access point.
