Brief For The Reminder App For Windows 7 And Features Too
Hello, brief for the reminder app for windows 7 and notify its key features too for the reference and thanks for solving and reply asap as well.
Hey, the reminder app for windows 7 helps to maintain the entire task for the person you get lost with all the details. It helps to manage and give the alerts as well for the reminder of the vents as per the settings done also separates each work form other time to time as well. Below show its key features:
• It’s very easy to install and uninstall the same
• It will provide you with more than 30 skins to customize if needed.
• Easy to manage the task for the office packages.
• It has a 12 months calendar with its week too for easy reminders.
• Gives the alert messages when needed
• Provides with the task list with the visual status too.
