Brief For This Application Has Encountered A Critical Error Error 132 With Specifications.
Varma Senm 10 points N/APosted on - 03/24/2017
Hello, notify the various Os supported for this application has encountered a critical error error 132 and also mentioned for the specifications for it in detail as well with its steps one after the other for the guidance too and thanks a lot
Hey, this application has encountered a critical error error 132 can be solved by installing the related software for the same and the same can be found over the web too and the latest version for the same is 7.14 and run over the systems too. Also supported in many of the OS platforms too. The specifications for the same are given below:
If you keep receiving an error when playing “World of Warcraft,” check the system requirements and verify that your computer meets those requirements. World of Warcraft supports 64-bit Windows 7, Windows 8.x, and Windows 10.
World of Warcraft
It requires Intel Core i5-760 or equivalent AMD FX-8100 or faster processor; 4 GB RAM; NVIDIA GeForce GTX 560, AMD Radeon HD 7850, Intel HD Graphics 530, or better video card with 2 GB video RAM; 70 GB free space; 1024 x 768 minimum screen resolution; mouse and keyboard; and broadband internet connection.
If there’s no problem, try to uninstall and reinstall. Download the free version of Revo Uninstaller and install. Once installed, start Revo then select World of Warcraft among the applications and click “Uninstall.” Follow the normal uninstall process. When uninstall is complete, click “Scan” to scan your computer for any leftover files and delete everything it finds.
This removes everything the program created on your computer. When it is finished, exit Revo then install the game back.
1....
