Brief Of Network Monitor Gadget Windows 7 And Its Features.
Hello, what is network monitor gadget windows 7 also notify its key features for the better understanding. Thank you for solving the same.
Hey, the network monitor gadget windows 7 is used to notify about the current network connections etc. also it notify about the network traffic through your IP address. Also the GUI is user friendly and can be used by everyone as well. Below shows the key features for the same:
• It displays both the external as well as internal IP.
• Also notifies about the upload, download speed etcs.
• It contains customize color for each of its elements.
• Can save the traffic counters on the external files.
• It also supports both wireless as well as wired networks.
