Brief The Recommended Internet Speed For Xbox Live And Its Steps Too
Hello, notify about the recommended internet speed for xbox live and also mentioned the steps to check the same as well. Thank you and reply ASAP.
Hey, the recommended internet speed for xbox live should be more than then 3 MBPS or it could not be less than 1 MBPs as most of the games are in high graphics and they required the said speed to run lag free also. The upload speed should range between 0.5-1 Mbps only. Below shows the steps for the same:
• First go to the guide button on the controller > setting > systems settings
• Next select the settings network
• Next select the name for the wireless network present
• Next select the network statistics
• Check the speed as the wireless device.
