There has been a recent problem in my PC that I need to solve. The brightness of my PC have suddenly faded.
I have tried to reconfigure it with best performance settings and increasing brightness in the graphics properties but things are still the same.
Everything is looking far darker than normal.
Should someone know how to solve this problem please notify me.
Mickey Nixon
Brightness problem-brightness has been reduced
Hello Mickey,
As you have said that you have tried to reconfigure it with best performance settings and brightness in the graphics. I had been suffering with the same situation several times and solved it with the removal and plugging in the CORD at the back of the Monitor.
You should try this as it might be the issue of your VGAÂ cord. If it is the case, you might have to replace the faulty CORD with the new one.
Well I will recommend you to use a blower to make a monitor dust free before replacing the CORD.
The dust may be affecting the buttons and the circuit.
Hope this helps.
