Brookstone fuel cell charger charges iPhone 15 times before depletes
Brookstone fuel cell charger charges iPhone 15 times before depletes.Imagine a USB charger which would make your phone be charged for roughly about 15 times before it runs out of current. is this applicable to all unit of cellphones?? or What unit of cellphones only can use?
Answered By 0 points N/A #157533
It is not applicable to all unit of cellphones but it can be used for most of the smartphones in the market today. It can be use and it is applicable for phones like iphone and smart phone on which they can charge their smartphone for about 14 times or around two weeks free from a wall charger.
The brookstone fuel charger uses replaceable fluid filled cartridge to continue deliver chargeseven after the initial cartridge is empty.And the replaceable cartridge will be available for a very low price.Another good thing about this product is that you can use it even for travelling in an aircraft.It can happen because of the unique process on which the solid oxide fuel cell membrane is deposited into a silicon water.
Most of the travellers and outdoor adventurers sees the advantage of using this fuel cell charger on their smartphone on which they can stay up to two weeks without charging and they can charge up to 14 times free from using a wall charger.
