Brother Printer Related Difxdriverpackageinstall Error 10 Fixed!
I purchased a printer yesterday, and I am facing an error today which is very frustrating. It says this difxdriverpackageinstall error 10. I am expecting an answer from someone on this site. Please answer soon. Thank you in advance.
Answered By 20 points N/A #311993
Hi, yes you will face this error when you are trying to install a Brother printer or mainly when you are trying to install software related to this printer. This error will stop the installation process and create problems for its customers. Corrupt system files or their absence on a specific path can be reasons for this error. I have come up with few solutions:
Solution 1: Use administrative rights to download printer software
• The software is present in the CD that is provided with the printer or you can get it from the official Brother Website.
• After locating the setup file of the software, right- click on it and click on Run as Administrator.
• Follow all the instructions that proceed further and, this will not give you any errors.
Solution 2: Download Microsoft Printer Solution
• Microsoft has developed a printer error troubleshooter which can be used to fix such errors. You can download it from this link
• Follow the instructions and finish downloading the Troubleshooter.
• Download the printer. I hope it solved your problem.
• If you have the Windows ten Creator Update, then you can navigate to Settings, then Update and click on Troubleshoot.
• Click on Get up and running section and then select Printer and begin troubleshooting.
Answered By 590495 points N/A #316841
If that installer came from the CD that ships with your printer in the package, check if the driver is compatible with your computer. If there is no way to verify the system requirements of the software, you can download the correct driver from the manufacturer’s website. For Brother printers, go to Brother Support & Downloads.
Here, enter your printer’s serial number or model number then click to search. You can find the serial number or model number printed on the sticker on the side or bottom of the device. When you located your product, click it to go to the download page. Before downloading, make sure to select your correct operating system. Normally, the page detects your operating system automatically.
If the page shows a different operating system, click to change and select your correct operating system. Download and install all available drivers and software for your printer.
