I am having a major problem with Google chrome browser. Each time I start the browser it seems to freeze the pc and I have to restart the pc again. I like Google chrome browser for its being fast in comparison. So kindly someone tell me what is causing the problem and how to solve the problem.
Daniel Murdoch
Browser causing the pc freeze on each startup
Hi, Daniel Murdoch. As like you I am also a user and fan of popular Google chrome. Seems your chrome have serious system or installation problem. Please uninstall your chrome. Remove all the data from your temp, recent folder (you can have access to those directly from Run Command, just type temp or recent in it and then press enter). Restart your pc. Then install the latest version of Google Chrome from https://www.google.com/intl/en/chrome/browser/. Hope this solve your problem.
Open Google chrome and press Ctrl + Shift + Delete together to delete those as showed in screenshot.
Try to use Adblock Extension to speed up page loading time while browsing. Try not to open too much tabs as it will slow down your browsing speed. These processes you help you to speed up.
