Browser Displays Google.com Certificate Error Message
Hi, I keep getting google.com certificate error message? How can I troubleshoot it? How do I make sure that it never happens again?
This error occurs when the signing certificate of authority is not trusted by your web browser’s configuration. To troubleshoot it, follow these steps
Step1: Log-on to Admin Console, then administration and then select SSL settings.
Step2: The currently installed certificate is shown on top “current SSL Certificate Information section”.
Step3: Check if the proper certificate is installed.
To fix this issue,
1. Ignore the warning or set an exception so that the browser ignores it in the future.
2. Only access the application over HTTP
3. Install valid SSL/TLS certificate
4. Export the search engine self-signed authority.
If you keep getting an error with your Google Chrome browser, try to uninstall and reinstall. Download the free version of Revo Uninstaller and install. Once installed, start Revo then select Google Chrome among the applications and click “Uninstall.” Follow the normal uninstall process. When uninstall is complete, click “Scan” to scan your computer for any leftover files and delete everything it finds.
This removes everything the program created on your computer. When it is finished, exit Revo then install Google Chrome back. If this doesn’t work, update your browser to the latest. For Chrome, go to the Google Chrome download page and get the latest version. This link downloads the standalone installer. If the problem continues, use other browsers like Mozilla Firefox and Opera.
For Firefox, go to the Mozilla Firefox homepage and download the latest. For Opera, go to Opera for PC and download the version for your operating system.
