Browser issue specifically internet explorer
Why is Internet Explorer 9 doesn't work on Windows 7, 64 bits?
My suggestion would be to reset the settings once again because this problem occurred to me as well, but after doing this (as instructed below) it solved and now its working fine.
Hope these procedures works with you.
You are facing problem in using Internet explorer 9 in your windows 7 64-bit. But Internet But Internet explorer is compatible of running windows 7. Sometimes Internet explorer crashes or closes immediately.
Sometimes it crashes and you might get error messages that internet explorer has stopped working. You have to make sure that your Internet connection has no problem. If your internet connection is ok, you can reset up your internet explorer 9. This problem occurs due to low memory or corrupted or missing files.
You can clear all history and restart your Internet explorer. Restarting your PC memory will clean. Then open the internet explorer or re-install it. If still any problem use Internet explorer 7 or 8 or another fast browser like Mozilla Firefox 4 or 5.
It seems if you will look for a download of Microsoft Internet Explorer 9, you will not find a compatible version for Microsoft Windows 7 on the Microsoft website. It will only direct you to a download that is designed for Microsoft Windows Vista. I think they are no longer providing the one that works with Windows 7.
I also noticed a lot of downloads and articles from earlier versions of Microsoft Windows have been removed. That’s why when you ran into a problem and you are using an earlier version of Windows like Windows XP and Windows Vista, you will not find an answer from the official website. You will end up looking somewhere else.
Anyway, here’s a download for 64-bit Windows 7 from FileHippo: Microsoft Internet Explorer 9 for 64-bit Windows 7. This download supports 64-bit Windows 7, Windows 8.x, and Windows 10. There is also a separate download for 32-bit Windows 7: Microsoft Internet Explorer 9 for 32-bit Windows 7. It supports 32-bit Windows 7, Windows 8.x, and Windows 10.
