Browser problems on LG Optimus
I can’t use the internet on my LG Optimus phone.
Whenever I go to the browser and choose a particular site on my bookmarks,it will load first then it will restart the phone.
Is that a sign that I have a virus on my phone?
Answered By 590495 points N/A #119944
It seems that LG Optimus has a lot of issues. There are other phone owners that experiences random restarts with their phone. Others experience a lot of sudden freezing of the phone, the calls are muffled, and it heats up fast. With you, it is the phone’s restarting problem whenever you go online with your phone. Other phone owners say that it is because of the stock SD card that it uses.
There are some that have minimized their problem with this phone, if not fixed, by changing the SD card. They suggest changing to class 4 microSD card or even class 6 if you can afford it. There are users that experience a much lesser instance of random restarts everyday after changing the microSD card. But I think the random restarting of the phone is there to live and can never be removed or fixed. I think this is the phone’s bug.
With your problem, try using Opera browser on your phone. There is a user who has the same problem as you are and fixed it by using a different web browser on the phone, which is Opera.
