Joseph Hill
360 points
Posted on - 05/28/2011
I spend most of my time searching and surfing the net everyday and I have a problem with my browser. The problem is that when I open all web page using Internet Explorer (version 8.0) or Firefox (version4.0), all colours disappear. The background color is grey and the text appears in either grey or black colors. I have tried other browsers like Google Chrome but still the display remains the same. Some of the images are displayed but some do not appear at all.
I took my time and carefully checked the properties of my Internet Explorer and Firefox. I had them confirmed with a friend’s laptop, the problem is not in the application’s settings.
I checked my graphics card properties and carried out diagnostic test. The drivers are fine.
I am using a HP G60 laptop
Windows 7 Ultimate OS
Processor -Pentium (R) Dual-Core CPU T4300 @ 2.10 GHz 2.10 GHz
Installed RAM -4.00 GB
32 bit Operating System
The color properties of both Internet Explorer an Firefox are ok, if I may repeat.
I have tried to look for online solution, ideas from friends, nothing is working. This is really frustrating. I've tried so much so far without luck.
Please offer as many possible solutions as you can. I will be grateful for any help.
Thanks very much!
lee hung
75 points
Browsers having problem in displaying colored images
Hi Joseph,
This seems to be very annoying. Here are solutions you can try to fix that problem:
Firefox Page Style – There is a setting in the Firefox browser where you can view a website to its default style or not.
Open Firefox
View
Page Style
Select or put the dot to Basic Page Style
Internet Explorer – Same as Firefox, there is a setting where you can view a website on its own style or not.
Open IE
Click Page
If you don’t see the “Page” option, right click on the empty space beside an open tab and select Command Bar
In the drop down menu under Page, select Style
Choose Default Style
Chrome – You can also change some settings in Chrome to help load the pages better.
Open Chrome
Click the Wrench icon on the upper right hand corner
Select Options
Under the Hood
Put a check mark on Use DNS pre-fetching to improve page load performance under Privacy
Chrome Images and Javascript – Since you mentioned that some images are not showing up and have not specified websites that this problem occur, it could be related to Javascript since a lot of websites use javascript to make their website.
Open Chrome
Select Options
Under the Hood
On Privacy, Press Content settings…
Click Allow local data to be set (recommended)
Click Show all images (recommended)
Click Allow all sites to run JavaScript (recommended)
High Contrast – Try to check or change if you have a High Contrast Setting
Control Panel
Accessibility Options
Display tab
Remove the check on Use High Contrast
OK
Internet Options Colors – Since this problem happens on all your browsers, then the problem may be on a general setting
Control Panel
Internet Options
General tab
Under Appearance, press Colors
Put a check mark on Use Windows Colors
OK
Internet Options Accessibility – As mentioned above, this problem may be due to a general setting since it applies to all the browsers.
Control Panel
Internet Options
General tab
Under Appearance, press Accessibility
Remove the check on all boxes
OK
Hopefully one or more of these solutions will help you remedy the problem. Good luck!
