annelforth
30 points
Posted on - 09/07/2012
I saw a Bt100 wireless audio receiver and it was cool, I am planning and wondering if I buy some of that it will be compatible with windows 7 operating systems and its driver, if a driver is needed for that software where can I possibly download it for free?
Bt100 wireless audio receiver in win 7 driver
The Cambridge Bt100 wireless audio receiver is a great receiver worth buying. The good thing is that it does support any operating system or program, therefore streams music stored regardless. It works wireless  whether music is stored on your iPhone, iPad, tablet, Smartphone or any device you are guaranteed of accessing it so I don't think you should worry much about getting drivers.
Hi Annelforth,
With the new Cambridge BT100 wireless audio receiver you can turn your computer into a wireless hi-fi device. You can also connect this device with your Smartphone, tablet or any device that supports Bluetooth. When you purchase the Cambridge BT100 wireless audio receiver necessary driver are supplied with it and not need for you to download them.
If you want you can download the user manual here http://heresthethingblog.com/2011/10/11/mac-os-lion-tip-sort-rearrange/
Take a look at the image below and you can have a better idea how it works.
