Buffalo DriveStation 500GB USB 2.0 (HD-CE500U2) External Hard Disk ejection error
40 points
Posted on - 10/22/2012
Hi guys,
The problem is with my Buffalo DriveStation 500GB USB 2.0 (HD-CE500U2) External Hard Disk.
I am using it on my machine for two years without any discrepancy. Last week I received an error message and found that the disk did not take back up.
Have a look at the error message. It is indicating about the improper ejection.
But I am sure that I had not removed the disk from my machine for the last one year. Have you any idea for the issue?
Please help.
Thanks in advance.
The disk was not ejected properly. If possible, always eject a disk before unplugging it or turning it off.
To eject a disk, select it in the Finder and choose File > Eject. The next time you connect the disk, Mac OS X will attempt to repair any damage to the information on the disk.
OK
