BUG CODE USB driver error
My PC is 30 years of using, the first one is Vista, which I miss it. please assist, I eventually left the laptop on and attached to the network, last Friday night. I stay in a country wide forest so my only option for the internet is to switch up network. When I come back to laptop after lunchtime, the computer mouse is not functioning. I receive a concept regarding the "click on this percolate to support" and "the system is not identified". Knowledgeable to remove the mouse and reconnect it that didn't function. Then knowledgeable to try another program in the slot also did not function. I applied the rabbit in a various USB slot – yet no reaction. It dawned on me to attempt the printing device, no, no move there as well. I go to concept board assist in various locations. I am not using any x box or pink teeth, none either . I determined that I need to apply the involved drives and do a total program recover. At that factor I got the BUG CODE USB Device concept. When I look to this concept board, I visited on the "test your drive's" AD. Right after 40 minutes (dial up) it knowledgeable it didn't function with 64 bit. Previously I am trying to fill a video activity title space and it would not fill because it doesn't work the 32 bits. A
ybody has recommendations? I am delayed with this. Thank you very much.
