Build application of date and time themes for Windows XP
Hello, I want to get the PHP coding of date and time theme. Actually, I am using windows xp. I want to create an application which will make date and time themes for windows xp. It's would be great if I can do it. Please help me!
Answered By 30 points N/A #182104
Hi Mr. Garett,
I have been reading about your worries in creating date and time on windows 7.  I have this short procedure to follow. Kindly learn it and apply on your windows 7.
Here are some images that will help you:
The DOWNLOADING Option: download then Run and Save this file (Date_and_Time.Zip)
Learn this sample of date and time shortcut first;
As you can see on the next picture; easy step follows
After saving and opening the zip. file on the desktop
*Pull out  the DATE AND TIME from the desktop
*Get on the PROPERTIES
*hit the GENERAL dialog
*snap the UNBLOCK for security reason of your PC.
*shift the shortcut base on your needs
Hope this could help you.
Thomas
PLEASE CHECK THIS OUT TOO:
THANKS
